TATRA8X8
Re: EXPEDIČNÍ VŮZ
ned lis 17, 2019 4:51 pm
toulavejtom
Re: EXPEDIČNÍ VŮZ
https://www.facebook.com/tomas.t.kouba/ ... 901668259/
slavnostní odjezd Tatry kolem sveta 2, z Neratovic
ToulavejTom
pon úno 24, 2020 8:05 am
Paweł WBOH
Re: EXPEDIČNÍ VŮZ
Hello, I will build, I hope in 2021, the expedition truck (my next one) on the Tatra Phoenix 6x6 (new). By the way it will be more motorhome than expedition truck. Im living now in Iveco Daily 4x4 but need someting bigger to my family. It is my only home what I have, we started the journey 15 months ago, and now we re after 25 000 km. If you're interested look at: https://web.facebook.com/worldbyourhome/
I will have few questions to you all, who know that truck.
That will be great when someone can answer me, if find some time for that. thank you in advance :)
1. The tyres, - I need the smallest but ONLY SINGLES at the back, do you think when all will be up to 16tones, and 6x6, with the 12R20 will be enough? or must be minimum 14R20 (the weight index i critical I guess). Is anyone using that tyres (12 or 14R20)? Im fighting to have truck with box lower than 3,75cm and tyres are very important to get that height.
2. What is the common fuel consumption (Im thinking about MX11, 430HP). when on highway? Is possible to catch 26-28 litres / 100 km (when total 16 tonnes)?
3. Someone maybe have an picture and can paste here or just send me on mail - paw.mal@icloud.com - the 6x6 Phoenix with additional fuel tanks? Imsearching it, but no sucess. I need to plane the boxes on everyside and it is important.
4. Is the 16 gear ZF Tronic Automatic gearbox is the a problematic? i.e. are there frequent failures? Is it freezing? Does it require service or does the Paccar-enabled computer also support transmission software if any troubles?
5. I know that the factory can change / remove all of the technical equipment at the back of the cab - I need have tunnel to he box, and the space between cab and box should be as lower as can. Do you anyone have an picture of that removed instalation ?
is a few questions only, next soon :)
thank you.
The Czech version by translator : :)
Česká verze překladatelem: :)
Dobrý den, postavím, doufám v roce 2021, expediční vůz (můj další) na Tatra Phoenix 6x6 (nový). Mimochodem to bude více obytný automobil než expediční vůz. Nyní žiji v Iveco Daily 4x4, ale potřebuji něco většího pro svou rodinu. Je to můj jediný domov, jaký mám, cestu jsme zahájili před 15 měsíci a nyní jsme znovu po 25 000 km. Pokud vás zajímá, podívejte se na: [url] https://web.facebook.com/worldbyourhome/ [/ url]
Budu mít pár otázek pro vás všechny, kteří znají ten vůz.
To bude skvělé, když mi někdo může odpovědět, pokud na to najde nějaký čas. Děkuji předem :)
1. Pneumatiky - - Potřebuji ty nejmenší, ale POUZE JEDNOTKY, myslíte si, kdy bude vše do 16 tun a 6x6, s 12R20 bude stačit? nebo musí být minimální 14R20 (myslím, že index hmotnosti je kritický). Používá někdo tyto pneumatiky (12 nebo 14R20)? Bojuji s nákladním vozem s boxem menším než 3,75 cm a pneumatikami, které jsou velmi důležité pro dosažení této výšky.
2. Jaká je běžná spotřeba paliva (myslím na MX11, 430HP). kdy na dálnici? Je možné ulovit 26–28 litrů / 100 km (celkem 16 tun)?
3. Někdo může mít obrázek a může ho vložit sem nebo mi jen poslat poštou - paw.mal@icloud.com - 6x6 Phoenix s dalšími palivovými nádržemi? Hledám to, ale žádný úspěch. Musím postavit krabice na everyside a je to důležité.
4. Je 16-stupňová automatická převodovka ZF Tronic problematická? tj. dochází k častým selháním? Mrazí? Vyžaduje servis nebo počítač Paccar také podporuje přenosový software, pokud máte nějaké problémy?
5. Vím, že továrna může změnit / odstranit veškeré technické vybavení na zadní straně kabiny - potřebuji tunel do boxu a prostor mezi kabinou a boxem by měl být co nejmenší. Máte někdo obrázek, že odstraněná instalace?
je jen pár otázek, příště brzy :)
Děkuji.
stř bře 04, 2020 6:11 pm
Pápa
Re: EXPEDIČNÍ VŮZ
Tatra 815 safaribus
Obrázek Obrázek Obrázek
pát kvě 29, 2020 5:28 am
pavel 815
Re: EXPEDIČNÍ VŮZ
Nějaké info k tomu ,,raketoplánu,,?
sob kvě 30, 2020 12:00 am
Pápa
Re: EXPEDIČNÍ VŮZ
Ňáký info jsem našel tady na fóru:http://www.truck-forum.cz/forum/viewtop ... &start=705
Naposledy upravil(a) Pápa dne sob kvě 30, 2020 12:49 pm, celkem upraveno 1 x.
sob kvě 30, 2020 12:45 pm
Pápa
Re: EXPEDIČNÍ VŮZ
Jinak o tomhle vím,že se vezl z Čech do Francie odkud jede do Afriky.
TATRA8X8
TATRA 158 PHOENIX 8X8
pát čer 05, 2020 9:37 am
TATRA8X8
Re: EXPEDIČNÍ VŮZ
úte črc 14, 2020 2:41 pm
TATRA8X8
TATRACPHOENIX
pon srp 31, 2020 7:20 am
TATRA8X8
Re: EXPEDIČNÍ VŮZ
Foto : David Petrák
sob říj 31, 2020 8:52 pm
lucaaaasss
Re: EXPEDIČNÍ VŮZ
To vypadá hodně dobře na expedici jako dělane
čtv lis 05, 2020 12:28 pm
TATRA8X8
Force
ned lis 15, 2020 5:44 am
PtrialM
Re: EXPEDIČNÍ VŮZ
úte bře 09, 2021 8:05 pm
filip 90
Re: EXPEDIČNÍ VŮZ
Hm zajímavý. Podle světa motorů je to podvozek T815 P18 28 235 6x6.1. To by znamenalo, že to má V12 atmosféru motor. Zas na druhou stranu podle udávaného roku vzniku (polovina 90. let) by to měla být Euro 2. :think: Leda že by podvozky byly starší a nebo je nepřesný rok vzniku aut.
Filip Nikl
úte bře 09, 2021 10:33 pm
Zpět na „TATRA“
